Kabel pro diagnostiku - zkušenosti, doporučení
Vše okolo diagnostiky
Skury
Re: Není tento kabel podezřele levný?
Příspěvek od Skury »
Ivarek: Je to tam napsaný...
* Diagnostic via CAN and Special functions via K-line
* Covers all electronic control units in vehicles (diagnostic addresses from 0x01 to 0x80). This can allow of user to investigate and diagnosis some new units untouchable for remaining diagnostic tools. Functions are under CAN-TP2.0
* Manual definition of running diagnostic session ¡¡ìC not like remaining diagnostic tools always standard diagnostic session 0x89. Function is under CAN-TP2.0
* Broadcast diagnostic request, disable normal communication, clear DTCs, Logistic (transport) mode,.... Functions are under CAN-TP2.0
* Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0
* Most of popular diagnostic requests, identifications, coding, adaptations, DTCs and s.o. Functions are under CAN-TP2.0
Special functions
* Odometer correction in instrument clusters and EDC15x
* Read Security Access Code/Login WFS
* Read/program immobilizer data
* Read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K
* VAG MMI TV Activation
* Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8, Porsche
* Key learning buttons for easy usage (not needed security code). Can do component security authorization
* Key learning Porsche CAYENNE (not needed security code) K+CAN
* Custom memory reading from different units like ECUs, EZS-Kessy and s.o.
* Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories
* Crash data clear in airbag units
Raceman
Příspěvek od Raceman »
kua necelých 1100,- i s dopravou za CAN to je dobrá cena a podle popisu umí K i CAN linku
Příspěvek od Ivarek »
Škury...jojo,to jsem četl (teda překladačem ;) ) ale jestli to opravdu umí...myslel jsem jestli ho někdo nekupoval a nemá ho odzkoušenej.
Alf
Příspěvek od Alf »
Jj, recenze by se hodila. Až budu řešit jiný auto, tak by se mi taky hodil.
Jinak jaké jsou vlasně typy CAN kabelů ? Pro přístup do tachometru apod. je potřeba hex-can, který má seriové číslo, nebo jak to vlasně je ? Pro normální diagnostiku a nastavování by mi stačil normální CAN ?
1.3 Mpi, 50kW, 2000, Special,
Servo, klima, ABS, 2x Airbag,
Skury
Ivarek: Já to chápu, ale byla by to náhoda asi jako výhra ve sportce, kdyby tenhle kabel tady někdo měl... Tenhle kabel to zkrátka umět bude.
Alf
Příspěvek od Alf »
Škury...já vím,no,zkusil jsem to.
Alf...ty jo to je diskuze,to si pročtu.
markos29 - FK
Re: Diagnostiký kabel ELM327
Příspěvek od markos29 - FK »
Zdravím ohledně toho ekm327.Zkoušel jsem to na různých programech,ale pořád nic.Poradíte mi prosím?Myslím si,že v programu se musí dát nastavit rychlost 9600 baud.A proto to asi nefunguje.Jaký by jste mi doporučily?Díky moc
markos29 - FK
Mám takový dotaz.Jaké má Felicia protokoly?A jakou nejvyšší rychlost by se musela nastavit?Díky moc
markos29 - FK
toto jsem našel na netu:
Tak mě se to tu válelo dodnes...asitak před 1/2 rokem mi to poslal dodavatel místo RS232 verze...nebyl čas to řešit.
Tak jsem to teď otestoval. Zprovoznění je stejné, jako u jakéhokoli jiného kabelu s FTDI...
Z této stránky http://www.asix.cz/ftdrivers.htm si stáhněte ovladače pro virtuální sériový port (VCP) a nainstalujte. Do OS se přidá další COM port, tak přes vlastnosti nastavit na nějakou rozumnou hodnotu, třeba COM4. No a v základním nastavení SW scantool (http://www.scantool.net/index.php) nastavit správný port a změnit přenosovou rychlost z 9600 na 38400!! Všechny čipy ELM327 komunikují touto rychlostí a v tom bývá ten zádrhel...starší, třebas ELM322 jede na 9600...
No a musí to fungovat, pokud není vadný kabel...
Může to být i tím? Díky mco
markos29 - FK
zdravím dá se nějak nastavit na tom elm327,aby fungoval jako ty předchozí verze elm323 atd. co umí rychlost 9600 a mojí feldu?díky moc
mir77 - FK
Diagnostický kabel
Příspěvek od mir77 - FK »
Ahoj, tak úplně to sem nepatří, ale určitě se najde někdo, kdo mi poradí. Přesedlal jsem na Octávku a rázem je na ní můj kabel z Aukra s VAGem 304 krátkej :D Mohl by mi někdo doporučit kablík, kterej bude komunikovat s VAGem, bude za rozumnej peníz a poradí s Octavií r.v. 2002, 1.9 TDI 81 kW?
Ten co jsem měl jel vpoho s Feldou 97 a Fabií 1.4 2001.
Tomas6
Re: Diagnostický kabel
Příspěvek od Tomas6 »
2002 by ještěměla chodit s kkl kabelem...
mario30 - FK
Příspěvek od mario30 - FK »
Zdravím.To jsem já markos29.Chci se zeptat.Vyřešil jste to někdo stím elm327 a Škoda Felicia 1.3 50KW r.v.96 řídící jednotka Bosch?Díky moc
mario30 - FK
100% by to mělo chodit.Protože kamarád má Fabii 2004 a s KKL kabelem to chodí v pohodě.
mir77 - FK
Zjistil jsem, že byl problém ve VAGu když jsem teď napojoval znova Feldu. Anyway, ten VAG je nějakej nechutně pomalej. Jedu to na Windows XP Pro SP3, v notesu je dvoujádrovej turion, 2 GB paměti, takže to určitě neni problém. Ale vždycky když jsem kliknul na nějaký tlačítka, tak trvalo neuvěřitelnou dobu, než se to hnulo. Je to VAG-COM 4.09, kterej jsem tenkrát dostal přímo ke kabelu. Čím to?
mario30 - FK
No a nemáš tam vira?Nebo zkus Vag-Com 304.Mě to funguje v pohodě.
mir77 - FK
Nene, zadny breberky 100% nemam :) Ale zajimalo by me, jak to je s tema K-Line a CAN Bus vychytavkama, co treba s Vagem 3 nemuzu oproti Vagu 4 a co nebudu moct na zminovany Octe ani se ctzrkovym Vagem.
Tomas6
Myslím že jediný kdo by to tu měl vyřešit si ty,protože tento kabel tu nikdo nepoužívá.Takže to nikdo neřeší....Nechápu proč jsi ten kabel kupoval když ti to všichni rozmlouvali.Na feldu ti stačí obyč KKl kabel za 500 z aukra a pokud chceš diagnostikovat Can tak už jedině origo kabel...Nestojí takový balík aby se ti nevyplatilo do toho jít když nechceš jezdit do servisu.
Karell
Příspěvek od Karell »
Zdravim poradite pujde tento kabel na feldu 1996-Bmm a na 2000-mpi obe 1,3?? jde mi jen o nejake nastaveni klapky a kontrolu lambda sondy. Diky. Hledal jsem ale nejak nemuzu najit neco jsem tady kdysy cetl o techto modrejch ale uz netusim co se psalo.
http://aukro.cz/show_item.php?item=1326 ... esl%C3%A1n
no design car...
no tuning car...
no style car...
no city car...
only My car... :) -> MotorExcel
Sadra17
Příspěvek od Sadra17 »
po čase přestane komunikovat ;) radši bych vzal http://aukro.cz/item1319738699_diagnost ... aruka.html
Tomas6
Vidíš.A já ten modrý mám a už docela dlouho a komunikuje...Tak nevím no.
Surmi - FK
Příspěvek od Surmi - FK »
Vždyť tam je snad rozdíl jen v barvě toho kabelu ne? :D
Sadra17
Tomas6 píše:Vidíš.A já ten modrý mám a už docela dlouho a komunikuje...Tak nevím no.
já už se s tim párkrát setkal ;)
Yany - FK
Příspěvek od Yany - FK »
Ja takyto kabel mam, (mam ho koli inemu autu) a ked som ho napojil na VAG tak sa tam neobjavila moznost vyberu kabla bolo tam len kkl a este nejaky, elm tam nebol tak som to dalej neriesil, ale mozno mam len staru verziu VAGu.
Stefi - FK
Re: Kabel pro diagnostiku - zkušenosti, doporučení
Příspěvek od Stefi - FK »
Dobrý den, kabel ELM 327 bohužel s feldou nepůjde,protože je to určeno pro vozy od r.v.2001 neboli které mají OBD II,mám ho doma taky, na Fiata v pohodě,ale ve feldě určo jsem si ani neštrejch :lol: Jinak kabel umí jen číst data a mazat paměť závad,což ohledně airbagů je OUT :? ale na základy to stačí ;)
Jara.K - FK
Příspěvek od Jara.K - FK »
Vůbec nemůžeš nainstalovat vag nebo se ti nechce spojit s autem?
Vit125
Příspěvek od Vit125 »
Zdrvim, mam obyč kabel z aukra, takovej ten modrej, na feldu a na octavku 99 mi stačil, ale chci kupovat fabii 1 2004 a tak se tedy ptám, zda bude tento kabel na běžnou diagnostiku stačit ( čtení a mazání závad). Díky za info
satik
Příspěvek od satik »
Zdravím mám tady tento kabel http://www.eshop-rychle.cz/diagnostika- ... UDI-SEAT... už se stím asi tejden mr...ám a nemužu to rozjet na Win 7 64bit několik piv vypitejch nervy vytečený jak olej z převodovky a furt to nemužu rozjet mužete mi prosím poradit?? Teda dočetl jsem se, že spíš na XP to jede v cajku akorát zas kupovat nějakej noťák kerej bych měl jen na diagnostiku je takový nachuja. pls help
LucasCZE
Příspěvek od LucasCZE »
Levne kabely z eBaye ci Aukra funguji pouze na 32bitovych systemech, takze tady bych hledal stejnou chybu. Bud to smaz a dej si tam Win 7 32bit, pokud teda 64 bitu nevyzadujes/nepotrebujes, nebo si udelej dualboot s Win 7 64bit a Win 7 32bit...
satik
Jak to udělat ten dualboot ?tady vtomto jsem dá se říct laik
LucasCZE píše:Levne kabely z eBaye ci Aukra funguji pouze na 32bitovych systemech, takze tady bych hledal stejnou chybu. Bud to smaz a dej si tam Win 7 32bit, pokud teda 64 bitu nevyzadujes/nepotrebujes, nebo si udelej dualboot s Win 7 64bit a Win 7 32bit...
Problém samozřejmě není s kabelama ale s verzí VAG-COMu.
satik
Kabel je v pořádku to mám odzkoušený, ale když jsem rozjel s kamošem vag com myslím, že to byla 304 nebo 409 tak to všecko fungovalo, ale nemohlo to rozpoznat kody, že to psalo otazníky tečky čárky atd... tak jsme zkoušely jiný codes a stejnak nic :(
Aleš
Příspěvek od Aleš »
satik píše:Zdravím mám tady tento kabel http://www.eshop-rychle.cz/diagnostika- ... UDI-SEAT... už se stím asi tejden mr...ám a nemužu to rozjet na Win 7 64bit několik piv vypitejch nervy vytečený jak olej z převodovky a furt to nemužu rozjet mužete mi prosím poradit?? Teda dočetl jsem se, že spíš na XP to jede v cajku akorát zas kupovat nějakej noťák kerej bych měl jen na diagnostiku je takový nachuja. pls help
zkus to, http://www.ftdichip.com/Drivers/VCP.htm
jinak tento kabel mám už hodně dlouho a max. spokojenost.
keenworth - FK
Příspěvek od keenworth - FK »
satik píše:Jak to udělat ten dualboot ?tady vtomto jsem dá se říct laik
Nevím co to je dualboot a jak na 64bitovým procíku jde rozchodit 32 bitovej systém, ale vím, že existuje nějakej emulátor XPček do 7ček, kterej si tam nainstaluješ a ten Vag pak jde... já jsem to zkoušel, ale nepovedlo se mi to rozchodit, takže jsem si prostě půjčil notas se 32 bitovými sedmičkami a šlapalo to.
LucasCZE
Ivarek píše:Problém samozřejmě není s kabelama ale s verzí VAG-COMu.
Presne tak, spatne jsem se vyjadril. Problem je pouze se softwarem (nebo ovladaci, tezko rict) na obsluhu kabelu, ktery nepocita s 64bitovym systemem.
keenworth píše:... vím, že existuje nějakej emulátor XPček do 7ček, kterej si tam nainstaluješ a ten Vag pak jde... já jsem to zkoušel, ale nepovedlo se mi to rozchodit, takže jsem si prostě půjčil notas se 32 bitovými sedmičkami a šlapalo to.
Emulator XPcek do Win 7 existuje. Je primo od Microsoftu, takze by to melo zarucovat nejakou kvalitu.. Nicmene bych se asi bal, ze ve virtualizovanem systemu (navic skrze 64bitovy system) nepujde emulovany COM rozchodit stejne jako to nejde ve Win 7 64bit...
Dualboot popisuji napriklad na MojeWindows.cz. Rozdil je v tom, ze ty nenainstalujes Visty a XP, ale 2x Win 7 (jednou 64bit, jednou 32bit). Pocitac se te potom pri kazdem spusteni zepta, jaky system ma nabehnout. 32bitovy system muzes mit jen na praci s kabelem, takze si na disku vyhradis treba 10 GB a budes tam mit vse pro diagnostiku... Tento navod jsem vybral namatkove, nejedna se o nic mnou overeneho, ale smysl rozhodne dava, nemel by byt problem...
Pozor: Pokud jsi, jak rikas, laik, muzes prijit o vsechna data na disku. Takze si promysli, jestli to radeji nekomu nesverit. Nicmene pocitac jako takovy tim pokazit nemuzes, takze krome dat nemas co ztratit. ;)
satik
No a když stáhnu ty drivery tak kam to pak nakopčit??
Mates
Příspěvek od Mates »
Mám potřebu si pořídit diagnostiku a vůbec netuším co koupit za kabel a co program k němu? Mám 1,3 bmm 1996 a rád bych ten kabel pak použil i do jinýho auta časem.
Díky za rady
Zkoušel jsi přečíst tohle téma ?
Mates
zkoušel. Půlka odkazů nefunguje a bohužerl se v tom nevyznám. Kažný píše co má a že mu to nějak blbne. Hodilo by se to nějak sesumírovat a já tomu hlavně vůbec nerozumím. Tak se omlouvám...
luk111
Příspěvek od luk111 »
Ahoj nemá někdo plnou verzi programu VCDS na diagnostiku, nebo nedoporučí někdo program na diagnostiku pro WIN7 64 bit. Jinak VCDS na tom chodí. Díky
Mates
Mám stejný problém, pokud bys věděl i o něčem jiným, tak mi to pomůže.. Zadarmo to nechci
Jara.K - FK
Zdravím potřeboval bych radu. měl sem VAG-COM na starým notasu s XP a ted mám jinej s win7 a nejsu schopen ho nainstalovat. Nenašel by se tu někdo kdo by to uměl nej. z Brna? Dík
HarryPotter1
Příspěvek od HarryPotter1 »
Ahoj,mám nainstalovaný V303,304,409 a 607 na W7 32bit.Používám ale převážně 304,neb je CZ.Nainstalovat jdou bez problémů.
Co přesně ti nejde nainstalovat?
Aleš
Příspěvek od Aleš »
Jara.K píše:Zdravím potřeboval bych radu. měl sem VAG-COM na starým notasu s XP a ted mám jinej s win7 a nejsu schopen ho nainstalovat. Nenašel by se tu někdo kdo by to uměl nej. z Brna? Dík
nejspiš máš win7/64bit, tam to nerozchodíš, použij VCDS-lite ale není v cz, nebo virtuálku XP.
panlada
Příspěvek od panlada »
zdarvím koupil jsem si tuto diagnostiku,ale nemužu se dostat dál jako například škrtící klapku http://aukro.cz/ShowItem2.php?item=3610 ... ommend-box
VAN3R
Příspěvek od VAN3R »
Nazdar.....Mam kabel HEX + CAN Dual-K CAN USB a pri pripojeni na Feliciu 1.3 BMM r.v 95 pri test kabelu na porte USB vypisuje toto: Ross-Tech USB rozhraní nenalezeno! Stav rozhraní HEX: nenalezeno. Pokud používate kabel USB ujistete se, že jsou spravne nainstalovaný ovladače. Naleznete je na instalacním CD
A pri porte COM4 vypisuje toto: Stav portu OK! Stav rozhraní HEX: nenalezeno. Pokud používate kabel USB ujistete se, že jsou spravne nainstalovaný ovladače. Naleznete je na instalacním CD
Pri ostatných COM portoch vypisuje to iste co pri USB porte!
Po skončení instalacie VAG COM VCDS naintalovalo aj nejake ovladace a ked som este pripojil kabel ku notebooku tak aj vtedy instalovalo niečo...takže uz fakt neviem ako to spojazdniť....poradte :(
*program ktory je ku kablu je VCDS 10.6.4 CZ
HEX rozhraní ve feldě nenajdeš .. to je v pořádku.
Na feldu potřebuješ kabel co zvládá komunikaci po K-line ( http://aukro.cz/usb-vag-kkl-obd-ii-diag ... 88876.html )
Program pro diagnostiku Vag-Com 3.14
Ten jeho by měl K linku taky umět....můj mi vypíše K1 line OK,K2 line OK a CAN nenalezeno.
Jarda28praha
Příspěvek od Jarda28praha »
Bude tento kabel v pohode fungovat a diagnostikovat Felinu ?? Jedna se mi o tento kabel : http://www.levnealarmy.cz/eshop/autodia ... &id_page=1
